94 Chevy K1500 gushing transmission fluid from front seal
Discussion in 'Member Introductions' started by amysantiques@hotmail.com, Nov 9, 2012.
  1. I've got an awesome 1994 Chevy K1500 with a 350 turbo transmission that is leaking or should I say gushing transmission fluid from the front seal bad and I need some help!!!
    When I started my truck the other day, transmission fluid started pouring out the front seal.
    So we replaced the front seal, changed the transmission filter, flushed tranny & made sure the vent tube wasn't clogged. But when we started it, truck is still GUSHING fluid from the front seal???? We cant figure out why???
  2. donyms
    Welcome to the club, it's good to have you aboard. I don't know anything about transmissions but if you post this in the tech section of this forum you will get better results. :glasses:
  3. Conlan Rose
    Welcome to the GMTC! I would post your issue in one of the tech forums with pics if you can and more description. Also add in how many miles it has. Your pump may be the problem or one of several things. It is odd that id only leaks while the truck is on no when it it sitting because it should at least drip from the leak while sitting.
  4. retired2001
    Welcome to the G M T C ! Good advice in the posts above! Good luck!
  5. SurrealOne
    We are the Borg. Lift your vehicle and surrender your keys. We will add your biological and technological distinctiveness to our own. Resistance is futile. Welcome to GM Truck Club!
  6. Curky
    Curky Epic Member 5+ Years 1000 Posts
    Welcome to the club
  7. Ethan
    Ethan Rockstar 100 Posts
    Why do you have a turbo 350 in a truck that should have a 4l60e? And my best guess on the leaking is that the front pump is toast.
