95 K1500 4l60E with no first gear
Discussion in 'Chevy C/K Truck Forum' started by seegreen1087, Sep 7, 2013.
  1. seegreen1087
    seegreen1087 New Member
    I just purchased 95 K1500 and, along with someone doing away with the emissions on the engine, I noticed when taking off the transmission starts in 2nd gear. ODB1 and No codes. I tested the A solenoid while driving (someone else was driving while I put a ground on the light green wire) and the transmission will shift into 1st gear. I'm thinking the computer being bad. Before I purchase another, does anyone have other suggestions?
  2. zippstripp
    zippstripp Member 1 Year
    Sounds like trans. pricing time. Although I did have a '94 full size bronco do this same thing. Solenoid pack and a ecm fixed that one.
  3. seegreen1087
    it appears the transmission is working fine, just not getting the signal it needs to activate 1-2 solenoid.
  4. BurbanMan
    Trace that wire to the ECM and see if the ECM is putting out signal
  5. seegreen1087
    With the engine running and transmission selector in over-drive, sitting in the driveway brakes applied, there is a 2.3vdc ground signal on E9 at the PCM. If I apply a good ground to that terminal the trans engages 1st gear. I'm just not sure if there is something else wrong that would prevent the PCM from providing a good ground signal to the solenoid.
    - - - Updated - - -
    It turns out the 1-2 solenoid was bad causing the trans to not have 1st gear. I put another solenoid in and everything works great. I was mistaken by thinking 4th gear was working, guess it was the converter lock-up making the change in rpms. Thanks for the advise.
