95" Suburban Fuse Liistings
Discussion in 'General Chevy & GM Tech Questions' started by Robs89wag, Nov 20, 2012.
  1. Robs89wag
    Robs89wag New Member
    Newbie to the site
    Replacing rotted fuel lines.
    Can anyone tell me which fuse controls the fuel pump 95 suburban.
    Thanks
    Rob:glasses:
  2. Pikey
    I would have to pull the cover off of the fuse panel and look at the diagram. The owners manual should also have a diagram of the fuse block. Are you trying to pull the fuse to disable the system so you can change the lines? If you can't find the fuse you can always pull the relay
  3. Robs89wag
    Thanks that did it.
    Wold you where I can get a fuel line diagram?
  4. Pikey
    I would go to gmpartsdirect.com and click catalog. put your vehicle info in and then select fuel delivery. you might have to search around. But, those are the same diagrams the dealer parts department has
