95 Z71 Heavy Half??
Discussion in 'Member Introductions' started by hskerprid, Mar 29, 2009.
  1. hskerprid
    hskerprid New Member
    Hi All, first post and question. I've been told by my mechanic that I have a 3/4 ton - ton frame under my 1500. It has a couple of plastic tabs in the frame marked HD and I have noticed in my repair manual that there is a C3HD model. It is not mentioned often in the manual is this a "rare" thing? My VIN say's that my truck is just a normal 1500 but looking at the suspension you can tell that it's beefed up. If this is a heavy half would there have been any engine modifications to it? I would like to put a 383 in it as the 5.7 has 204,000 on it and is getting a little tired( doesn't burn oil though!) Any thought's on this being a rogue model? What have I got exactly? Any suggestions on the 383 swap? I will probably keep the stock 5.7 and re-build it and swap them as necessary. Thanks!
  2. 95CTburb19
    95CTburb19 Epic Member 5+ Years 1000 Posts
    Welcome to the forum. Do you have 6 lug or 8 lug axles on there?
  3. tlperry68
    Call a dealer's shop, give tem the vin and they can tell you wat the truck was when it rolled off the line.
  4. Z71_guy
    welcome to the site
  5. dwill3015
    Welcome to the site!
  6. retired2001
    Welcome to the site! There were some 'light duty" 3/4 tons sold in '95, but I don't know of any "heavy duty" 1/2 tons. The "VIN" should "tell the tale"!
  7. bry2500
    Welcome to the site!!!
  8. MWright936
  9. Darstedly
    Darstedly Rockstar 100 Posts
    Welcome aboard. 'T'is mystery all.
  10. TrailLeadr
    TrailLeadr Epic Member 5+ Years 1000 Posts
    There's probably more to it than anyone realizes. I know exactly what you're talking about, because my 2002 1500 Avalanche has the same little gray plastic tab on the frame that says HD on it. Suspension-wise my Avy is definitely a 1500, of that I have no doubts.
    You might want to message 84Fiero123 and ask him. I haven't seen him online much lately but he used to work the assembly line at GM and might have some insight into what that's about.
