96 K1500 Suburban Slow Drain
Discussion in 'GM Electrical Tech' started by dbrine, Oct 6, 2010.
  1. dbrine
    dbrine New Member
    I have a 96 GMC Suburban K1500 and I have a battery drain. Has anyone else had this problem and how did you find/ fix it?
    The truck runs great but if it sits for a few days the battery is dead. It jumps fast and easily.
  2. 2wheelmudder
    2wheelmudder Rockstar 100 Posts
    well are you sure its draining? cuz i had a bad problem with mine starting, ended up i replaced the bolts that hook the wires to battery, easy replacement and cheap too...
  3. thrasher
    thrasher Rockstar 100 Posts
    Simplest way to find the current drain is this: disconnect the negative cable from the battery, and jump from the cable to the battery with a test light - it should light up if there is a drain. If so, start pulling fuses 1 at a time until the light goes out. When it does, you've found the circuit in question.
