96 sonoma crank no start, please help
Discussion in 'Chevy S10 Forum (GMC Sonoma)' started by vamblsk, Jan 30, 2014.
  1. vamblsk
    vamblsk New Member
    hi. for starters I am new to forums. first time ever. but I need some help. I work on cars for a living and well my own personal truck has stumped me and two other tech to the point we have no idea what to do or where to go from here. well here goes..
    96 gmc Sonoma 2.2l
    installed rebuilt engine
    crank no start
    checked for resistance and repaired if needed wires to crank sensor, cam sensor, computer, icm, coils, ground wires, fusible link wires, ignition switch wires, starter,. fuel injectors, power wires. 0.0 to .1
    no pulse width for crank sensor cam sensor or injectors.
    voltage checked to crank sensor cam sensor battery alternator pcm ignition switch starter icm coil fuel injectors. all are as they are suppose to be.
    tested all relays. all good
    fuses inspected and tested
    replaced crank sensor cam sensor pcm icm clutch peddle switch coils.
    misc. info... when cranking losing 2 volts goes from 12 to 10 volts
    sometimes loses communication with verus or solex computer
    cranks over good and strong
    no rpm signal
    crank and cam sensor will do a very small bleep when done manually
    locksmith verified no antitheft
    pcm has been replaced with a rebuilt and has been programed.
    thank you for your time
