96 Suburban Turn Signal Inop, ABS Problems & Convertor Problems
Discussion in 'General Chevy & GM Tech Questions' started by rowekmr, May 12, 2012.
  1. rowekmr
    rowekmr Member
    I have a 96 Suburban 2500 4x4 w/7.4L with 138K miles. When I bought it 2 years ago the brakes on the passenger side would cycle the ABS when stopping for the last few feet of the stop. I read that it could be the corrosion buildling on the mount of the speed sensor on the wheel bearing. When I asked a local shop about removing the speed sensor and taking off the corrosion they said that is extremely difficult and that they rather replace the whole wheel bearing. Is it that difficult to remove the sensor or should I just replace it all while it is taken apart? I removed the ABS fuse to eliminate the problem of the brakes chattering and the car pulling to the side, it was also dangerous because it could lengthen the distance to stop.
    Also I just noticed last week the turn signals don't work. WHen I use the turn signal level I don't hear any clicking or see the light on the dash that lets me know they are on. What could this be?
    I also have the hot start issue and want to replace the injectors with the Bosch 4 hole injectors. Is it smart to replace the fuel regulator also or is there a quick test that can be done on it to see if it is working properly? My floor boards get awful hot on long trips pulling the trailer and the heat is coming from the convertors. I am assuming that the engine is getting too much fuel or could it be something else?
  2. osgprometheus
    osgprometheus Rockstar 100 Posts
    I believe on those they are a hub assembly. You would be better off just changing bearing. It is 1 unit. As for the turn signal, check the flasher. If you dont hear clicking, check to see if you have power running through the flasher. Try changing that fist. As for the hot floor, if you get a laser temp gauge, check the temp before and after the cat.
  3. rowekmr
    rowekmr Member
    Hey thanks for the response. Where is the flasher located?
  4. dipstick
    Location of flasher www.gmtruckclub.com/forum/showthread.php/15937-1996-suburban-1500-turn-signal-issue#axzz1usL7MasB
    On the fuel reg. pull vacuum line off ..any fuel present bad. But do not think it is bad .
    Would have a long start issue all times . Are you getting a service engine light?
    Need to scan if so. Also if cat is getting hot probably already bad .
    Any unmetered fuel will ruin quick. I would clean the maf sensor and change coolant temp sensor if no service light.
    Coolant sensor located beside thermostat housing . Maf located in air filter system between filter ,and throttle body.
  5. rowekmr
    rowekmr Member
    No Check Engine Light. I bought this more than a year ago and put Sea Foam in the tank, used MAF spray cleaner and used TB cleaner in the TB and changed air filter. I only have the long start when it is hot. I only noticed the hot cat on long trip pulling 8.5K trailer and truck loaded up last summer. The last trip recently with trailer when it was 55F the floor didn't get as hot but the other times it was hot to the touch. I do notice the smell of gas occassionally after shut down (after a short time) but didn't know if the plugs were bad, or if it was coming from the induction side from the bad injectors.
  6. osgprometheus
    No prob man, what Dipstick said on the flasher location.
