96 Tahoe misfire cyl 2 after sitting a while
Discussion in 'GM Powertrain' started by Conlan Rose, Jul 20, 2013.
  1. Conlan Rose
    So my old girl keeps having a problem of misfiring after sitting for 3-4 days. The truck doesn't lose power but it just runs like crap. A flashing DTC for the misfire goes and then once the truck warms up a bit she runs great with 0 problems and the flashing stops. I read the code and it says theres a cylinder 2 misfire. i'm not sure whats causing the problem since if the truck is started every day she has no issues.
    I would love some advice on this so I can get it fixed up.
  2. pmf608
    My old Silverado acted like that on cold starts when I first got it. A new set of spark plugs, some fuel injector cleaner and a fresh fuel filter got it running like new again. It's a good place to start if either of those are fairly old. Checking your air filter and cleaning your mass airflow sensor probably won't fix the problem, but they'd be good things to do while you're at it.
  3. skjl47
    skjl47 New Member
    Hello; Perhaps the injector is leaking down after sitting for a time. This may allow excess fuel in that cylinder and ceate an over rich condition untill warmed up. This may also foul the plug a bit untill the fuel burns off.
  4. Pikey
    my 95 did the same thing. It only had 65,000 miles. I always chalked it up to a valve sticking.
  5. Conlan Rose
    I have the new fuel filter just haven't had the time to replace it. I cleaned the MAF about a month ago which helped the truck a bit and she has new plugs as of December this year, changed at about 199,000, currently at 201,400. Oil was changed about a month ago and I ran seafoam through the tank about the same time. Its likely just the truck disliking driving 120 miles of highway each weekend and then just sitting until halfway through the week for my night out and sitting again til the weekend.
    I just hope it isn't hurting the truck too bad.
  6. tbplus10
    I would recommend pulling the #2 plug and getting a look at how it's burning, but if I remember correctly the last time you pulled plugs you ended up with a bigger problem.
