97 Suburban battery keeps dying and heat/ac blower stays on
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by zx2max, Jan 13, 2013.
  1. zx2max
    zx2max New Member
    Two possibly unrelated problems with my 1997 Suburban. I replaced the battery back in August. Initially, if I hadn't driven the vehicle for a couple days the battery would die. Now it seems that I can jump it in the morning, drive to work, and when I get back to my vehicle 9 hours later it is dead. A couple weeks ago I did a draw test and I did not see an excessive draw. I think I was getting around 30 milliamps. Though I am not a mechanic so basically just googled the process. :) I think I'll give it another try today.
    Now on to my second issue which just started happening the other day. The blower is in the off position but it seems to be stuck in the high position.
    Any help with these two problems would be greatly appreciated. Thanks.
  2. MrShorty
    Definitely double check your test for parasitic draw. I would suggest not to assume the battery is still good. I know I've had a lot of trouble with batteries (especially the low end no name brands) in my Suburban.
  3. RayVoy
    Two types of blower speed control, one is the resistor pack that changes the voltage available to the blower motor. The other (which I think you have) is used on the auto HVAC controllers, it uses an electronic package to change the blower speed. The blower speed control module is available as a replacement part, or the existing assembly can be repaired (depending upon skill level). This is probably why the battery is flat.
