98 K1500 5.7L Suburban Rear Main Seal Leak
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by Caddiac, Nov 3, 2011.
  1. Caddiac
    Looks like the rear main oil seal is hemorrhaging. I have kept an eye on it for a while now. But have seen a dramatic increase in oil loss recently. I have seen single piece and two piece oil seals sold for this engine. Do any of you guys know if the seal used in the 5.7L of the late 90's was two piece or one piece?
  2. outalne94z71
    outalne94z71 Member
    all sbc 87 and newer had 1 piece rear seals, bbc went to 1 piece in 91 along with the 6.2/6.5
  3. Joeairforce
    Should be one piece...
  4. TMair
    TMair Member
    And that sucks, two piece are a piece of cake to change compaired to one piece, good luck.
    Terry
  5. Caddiac
    Talked to a local garage today that is highly recommended. The guy discouraged me from doing it because he said I would spend a lot of money and it may still leak. If I furnish the seal, I told him I would because I have a thing of GM OEM parts, he quoted me $400. What do you guys think? Is that a reasonable price and what would you do? The engine runs great and I would not hesitate to drive it to the west coast and back tomorrow. The only issue is it leaks oil to the point I usually need to add a quart between changes. I have never seen smoke come out of the exhaust on this truck. I do plan to have the compression checked before the oil seal replacement just in case. But regardless, the engine runs too good to need an overhaul or replacement. I am thinking I have at least another 100K which would put me at 350,000.
  6. tbplus10
    At the price he quoted you it's worth gambling on.
    It's hard to find and replace a good truck and you know you'll pay a heck of a lot more to replace the truck.
    I always say better the devil you know than the one you dont know.
  7. dipstick
    Try it yourself nothing to it ..drop drive shaft.. Pry old seal out.. Make sure you clean all good .. Check for burrs ect. On drive shaft.
    Start new seal in ..get a flat board ect. Peck it in till flush.. Reinstall shaft your done.
  8. TMair
    TMair Member
    I think it is the rear main oil seal in the engine, not the transmission.
    To change the rear main oil seal you would need to remove the transmission and the flex plate/flywheel, and you may have to lower the oil pan, I would think $400.00 would be a great price.
    Terry
  9. dipstick
    My bad ..... the main rear seal ... now that is a horse of a different color. 400 is a great price. I would watch.. do not see a garage of any rep doing this.
  10. TMair
    TMair Member
    And that is good advise, I would also make sure, perhaps in writing, that they warrenty their work.
    Terry
