98 k2500 running issues
Discussion in 'Chevy Truck Talk & GM News' started by tomx59, Feb 11, 2012.
  1. tomx59
    tomx59 New Member
    Was given a 98 K2500 that sat for two years. Fuel pressure is 60psi and compression is 155-168 on all cylindars. 5.7 liters but it isn't wanting to stay running. It will start and run 2 seconds with starter fluid only. Any help is greatly needed and welcome
  2. Coach24
    Drain the fuel tank and put fresh fuel that hasn't had condensation in it. Flush out all fuel lines then try again. After 2 years you may want to clean the fuel tank(s) and have them treated.
    Most likely water in the tank and lines after 2 years.
  3. tomx59
    tomx59 New Member
    Already have drained and refilled tank, blew out lines, change gas filter. Truck wants to start more if take the #1 plug out. Every plug has a blue spark. Even check the timing mark and it seems to be right. Thought the exhaust was stop up but it all disconnected now and same thing. It did try to start on it own the other day when cranking.
  4. Dana W
    Two words VAR NISH.
  5. gnfshn283
    gnfshn283 New Member
    I would look at the fuel injectors.
