98 Suburban 4wd question?
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by My98Suburban, Dec 18, 2011.
Newest Photos
  1. My98Suburban
    My98Suburban New Member
    Just bought a 98 Suburban K1500 i have a question about the 4wd..The switch doesnt see to light in any postion,2wd,auto or 4hi or 4lo but seems to work,then sometimes the light does go on in 2wd drive only?...What causes this?...is there any way to fix this?....Thanks...
  2. NagRuTan
    NagRuTan New Member
    Greets,
    Press hard around the switch site and see if they light up. A few of us have had loose contacts on the back side of the plugin.
    Nag.
  3. My98Suburban
    Thanks how does that switch come out so i can check that and clean the connections up?....
  4. NagRuTan
    NagRuTan New Member
    Greets,
    I pulled the dash to get to it. Not to hard (at least on my 99).
    Nag.
  5. My98Suburban
    Ok i will try pressing on the switch 1st then what else could it be if it doesnt go on? lite up?
  6. janikphoto
    janikphoto New Member 100 Posts
    My switch works fine, but it has a hole in it. I think the previous owner always pushed on it too hard and broke through the lit up part of the switch, where the plastic is thinnest. I plan to find a new one and just swap it out. You should consider doing the same if it's not a loose connection. At least the 4WD works. A switch is a cheaper fix than a solenoid or a transfer case!
