1. bagger
    bagger New Member
    Looking for a dashboard for a 98 Tahoe. Where is a good place to start. (I have a cover on it but the cracked dashboard rattles)
    Thanks
  2. moogvo
    LMC Truck has them for $999.95 plus freight. The best place to go is a boneyard. You can probably score one for about $200 or so. Then, putting it in will be a ROYAL pain in the dupa. Is the dash cracked along the defroster vents where the top 3 screws run through to secure it to the firewall? LMC also makes a kit to fix that. I just got some small "L" brackets from the local hardware store and inserted them like washers. Works great! no more rattle. the ones from LMC are a bit more refined and look a bit more OEM.
  3. bagger
    bagger New Member
    Thanks,
    Have used LMC for my 85 Blazer with no complaints. 1K is a little much. The dash is broke in 1/2 and broken at all 3 fasteners on the top. Called a couple of local yards but no luck but its not a emergency.
  4. bagger
    bagger New Member
    Used the small L brackets from the hardware store. JB weld the brackets in and JB weld the broken pieces back together.
    Put nice cover over it. Looks good, no rattle..
    Thanks
  5. Enkeiavalanche
    swap meets you can always find one Check Ebay?
