99" GMC Suburban Won't Stay Running
Discussion in 'General Chevy & GM Tech Questions' started by torianator, Dec 29, 2012.
  1. torianator
    torianator New Member
    hello everyone.hope for some help with problem.went to start sub and it would start but die.thought fuel pump so i changed it with oem one.ran great for 2 weeks but did exact same thing again.changed filter but didnt help.it does start and stay running sometimes.could it be engine temp sensor? thanks in advance for any suggestions
  2. Conlan Rose
    I would post this in one of the tech forums it will help you get a better responce.
    Have you checked the fuel pressure and that the injectors are spraying. Also have you checked the plugs? Do you have any codes, if you do get them checked and post them here.
  3. RayVoy
    I don't know your truck, but I'm guessing it has a fuel injected throttle body. A good cleaning will probably make a difference.
  4. Conlan Rose
    99 is SFI, actually all trucks from 96 on have SFI. Cleaning the injectors still may help if they are clogged.
  5. RayVoy
    Thanks @Conlan Rose
    Your right Conlan, it should start with dirty injectors, just run bad and maybe stall as soon as it starts, so it could be dirty injectors; but I'm wondering if gas is even getting to the injectors
    Have you checked the fuel pump relay? Can you hear the pump run?
  6. donyms
    Welcome to the club, it's good to have you here. :glasses:
  7. torianator
    getting misfire on 7.havent changed relay.will change plugs,wires and post results.thanks for advice everyone
  8. Conlan Rose
    Make sure you get the Delco plugs or in a year or two the same problem will come back. GM trucks love AC Delco plugs which are the OEM plugs.
  9. torianator
    thanks conlan rose
  10. Conlan Rose
    No problem. :smile:
