'99 Suburban A/C Too Cold
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by beltrunner, Jul 18, 2012.
  1. beltrunner
    beltrunner New Member
    So here's the deal...my '99 Sub has developed the problem of the A/C running too cold and freezing up the evaporator.The specs call for the clutch cycle switch to shut off the compressor at 25 lbs-low side, and turn it back on at 45 lbs. With a static pressure of 120 lbs, ambient air temp of 85 degrees, engine idle 1200 RPM: when the system is turned on the compressor activates and the low side pressure stabilizes at around 30-34 lbs...the high side sits at around 180-200 lbs...fan on high, max setting on temp control, the middle-front register reads 28-36 degrees. This is great for awhile until the evap freezes up and airflow is restricted. The lowside pressure will not drop down to 25 lbs to activate the switch to shut off the compressor. I even installed a new pressure cycle switch to no avail since the pressure will not drop enough to activate it anyway. So every half hour or so, I have to manually shut off the compressor at the control panel for about 5 minutes, and then start the process over again. The rear unit is controlled by the TXV and continues to function just fine (rear register temp 36-40 degrees). Any ideas on this? Thanks.
  2. bazar01
    bazar01 Rockstar 100 Posts
    Is it freezing up while driving or while idling at 1200 rpm during your test?
    Try revving the engine to 2000 rpm and watch the low side pressure.
    Usually, when the evaporator freezes up, it is low on charge.
    This happened on my 2001 last week during my 400 mile trip. It was low on charge. I found a small leak at the cycling switch. I just recharge the system with half a can of R134A and everything is fine after that.
