99 tahoe looses power pulling heavy loads uphills
Discussion in 'General Chevy & GM Tech Questions' started by paradise1, Dec 31, 2010.
  1. paradise1
    paradise1 New Member
    When I pull my utility trailer with a heavy load up steep hills the truck continues to lose power unless you keep your foot in it. It ends up shifting all the way to low. After I reach the top of the hill it has no power. I turn it off and something resets under the hood, it sounds like a door opens or closes, then it runs perfect until the next hill. I took it to a dealer in Casper WY and the replaced the fuel pump. This did not fix the problem ($784 later). It runs fine most of the time, but sometimes when I turn it off and restart it soon after shutting it off it hesitates for a while even without a heavy load. They said it had several codes like the MAP sensor, Cat back pressure but they all clear after you turn it off and then restart.
  2. stephan
    I'm not familiar with the sound you describe as a door opening, but this sure sounds like a fuel delivery problem. The fuel pump was a good shot because so many of them fail, but has anybody checked the fuel pressure regulator? Also if you can borrow a fp guage, hook it up & drive a steep hill with a load & see what the pressure does. It may be dropping like a rock.
    Plugged cats & exhausts can also cause lack of power & it's cumulative at higher speeds.
  3. retired2001
    Welcome to the G M T C ! I thing that Stephen is "right on" on your power problem and I'd bet on the cats.
  4. paradise1
    the dealer in Casper WY checked the whole exhaust system and said ther was no problems
  5. Enkeiavalanche
    What gears are in the truck? Did you change out the Gas Filter? Air Filter?
  6. paradise1
    The dealer replaced the fuel filter and it has a clean K&N air filter
    ---------- Post added at 01:53 PM ---------- Previous post was at 01:51 PM ----------
    The gears are whatevey came stock
    ---------- Post added at 01:54 PM ---------- Previous post was at 01:53 PM ----------
    what ever came stock
  7. stephan
    How did the dealer check the cats? What did they do?
  8. 2COR517
    There is no sensor/code for Cat back pressure.
    Dump the K&N, go back to a paper filter. That is causing your MAF issue. Hopefully you can just clean the MAF rather than have to replace it.
  9. murdog94
    *****thread moved here********
  10. Looey
    Looey Rockstar
    EGR valve. Have it checked.
