99 Tahoe trans swap??
Discussion in 'Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)' started by boomguy, Jul 29, 2012.
  1. boomguy
    boomguy New Member
    I have a early production 99 tahoe, sun shell broke in trans... I picked up an rolled 02 yukon on a trade just wondering if I can put the trans and transfer case out of the 02 into the 99... I dont have much experience with the 4l60e (old school, 350, 400 and 700r) but was told that it has a removeable bell.. any help would be appreciated..
  2. M-technik-3
    M-technik-3 Rockstar
    4L60e is a computer controlled unit correct? So I would assume that you would need all the associated items for the transmission to get it to function properly. But that is my wild a** guess.
    Boomguy as in Boomer on a KC type aircraft?
  3. boomguy
    boomguy New Member
    yes it is a computer controlled so is mine I have the whole truck but really wouldnt want to have to change all the harnesses...
    no boomguy as in aerial lifts...
  4. tbplus10
    If I remember correctly this is a straight across swap, I think it even has all the correct connectors for the harness.
  5. boomguy
    boomguy New Member
    is there a difference in the bellhousing? or do you know
  6. Boonduff
    The 2002 tranny was behind a LS style engine where you're 99 has a gen 1 350. The 2002 tranny will bolt up, but you will have one unused bolt hole at the top of the bell-housing, which isn't a big deal. The big problem may be the electronics, you're swapping between generations. I'd put the trannies side by side and compare electrical plugs, if they match you should be fine, if not you will have to do some rewiring.
