A/C airflow direction problems
Discussion in 'General Chevy & GM Tech Questions' started by 38racn, May 28, 2010.
  1. 38racn
    38racn Member
    1995 GMC Suburban 2500. Airflow won't change from floor/defrost position. A/C works but loses its effect by not coming from vents. Any help????
  2. vncj96
    your vent door in the dash is most likely broke or just gummed up by years of dust and moisture. thats the easy and cheap fix, otherwise its your actual HVAC controller not sending the signal to the motor to move the vent doors
  3. big bopper
    big bopper Member
    have the same problem on my Vandura, how would you get to the flaps ?
  4. vicar75855
    vicar75855 Rockstar 100 Posts
    Not sure about the '95 but my '99 suburban has a electric actuator right above the accelerator on the end of the a/c heater assembly its a black plastic afair with a plug and 2 screws also has a visible hole in the middle of one end. this switches from floor to face to defrost. once mine came unplugged and it stopped working and once I replaced it 10 min job at most if you have trouble finding the socket( Think it was a 7/32 but don't quote me on that)
    Hope this helps, GL
