A/C and Cabin lights will not come on...fan blows?
Discussion in 'General Chevy & GM Tech Questions' started by kev409, Apr 7, 2010.
  1. kev409
    kev409 New Member
    I own a 2000 Chevrolet Silverado with 146,XXX miles, I was installing a CB through my glove box light by splicing them in. I accidentally had both of the wires touch + and - touched in the glove box. I checked my fuses and they were all fine! Now because of this my cabin lights will not turn on in the doors, floor board, or my cargo lamp. My dash lights work, and reads CARGO LAMP ON.
    Another problem not associated with this is my A/C, the fan works but no cold air blows out, Ithought it needed a recharge and tried charging it, yet when the pressure read it was above 500 psi! FTW! I know there is froen in there on account of me being able to feel it numbing my fingers when trying to charge it through the port.
    I don't see the frost or condensation like I usually would on the unit in the engine bay. Fuses were fine and knobs are functional.
    Any help would be more than appreciated!
    Kind Regards to the Community,
  2. Springthing
    Hi kev-
    I'd check the fuses again, a different way than you did the first time. If you pulled one or two out and did a visual I'd get a meter and check the top sides of the fuses one by one, it should only take about 3 minutes to do them all. Also....I'm not sure if it would affect only a small portion of lights in the truck, you might want to check the fuses under the hood. May have had one of those go out although I think one of the smaller fuses in the cab would have popped first.
    I can't help with the A/C... good luck with it and your electrical problem!
  3. jedepsub
    jedepsub Rockstar
    On the A/c Part have you checked the pulley/ clutch on A/C compressor? The whole unit should turn with the a/c on. If the middle part does not turn, your clutch could be bad or power to the clutch.
