1. Chevy Truck Forum
    Welcome To GMTruckClub.com!
    Online since 2004, we're the #1 Chevy Truck & SUV user community. If you have any questions about your Chevy or GMC Truck, SUV or Crossover, or just want to connect with other GM owners and enthusiasts around the world, you've found the best place on the internet to do that.
    Join Today ~ It's Free
    Registering is Free and Easy! Do it today and we'll see you on the forums soon!
a/c condensation
Discussion in 'General Chevy & GM Tech Questions' started by oletrkguy, Aug 25, 2010.
  1. oletrkguy
    oletrkguy New Member
    I have a 1984 Silverado and from what I can tell some of the condensation is leaking into the passenger side floor board. I don't think it is from the heater core because the water is cold.
    Anyone ever have this situation before?
    How difficult it is to get to the area that may cause this? Also how difficult is it to get to the heater core?
    Thanks for the help,
    oletrkguy in SC
  2. RVJ
    RVJ Rockstar 100 Posts
    Find the drain where the water should be draining out and use a wet vac to suck the blockage from the drain tube. This will allow the water to drain out the hose as originally designed.
  3. oletrkguy
    Thanks for the reply, I will give that a try.
  4. oletrkguy
    I could not find a drain hose. It looks like the a/c tubes run into a large box that bolts to the firewall, but no drain tubes sticking down. I wonder if there is something inside of the box that is clogged. I am not famliliar with what is actually inside the box
  5. RVJ
    There is somewhere a place, a hole or an opening where the water should drain to the ground. When your truck is running with the a/c running do you see any water dripping to the ground? If so that is where to put your wet vac.
