A/C Questions 95 Silverado
Discussion in 'Chevy C/K Truck Forum' started by 95silv001, Jun 26, 2012.
  1. 95silv001
    95silv001 New Member
    Hello, I have a question about my A/C system. Does anyone know how much refrigerant oil does a new compressor and an accumulator take as I will be replacing both (from empty)? I can't drain out the old refrigerant and see because the guy already drained it from the compressor and did not want to continue. I believe the system takes 8 oz pag from empty. If this is correct, how much should I add the compressor and accumulator. is it 1/2 and 1/2 in each or less in the accumulator. NOTE: I will be flushing the whole system.
  2. moogvo
    Depends on the compressor. If you have the long one, it might take 8, althuogh that sounds a tick high... If you have the short "Pancake" one, I believe that one takes 4.
    Also, make sure to use the right PAG oil. They are NOT all the same. You want (I believe) PAG 130. Verify that before taking my word for it.
  3. 95silv001
    I have another question. I shorted the low pressure switch after installing the compressor and I was wondering, does shorting the low pressure switch verify that the electrical side of things are working? What components are there in the A/C system that would cause it to still blow hot after verifying that there are no leaks and that it has the correct amount of refrigerant in it and the system has no blockages? Is this possible? I can get the compressor to run at my will when I short the lps "by using the fan speed toggle" does this mean im in the clear when I go to refill it that I will have cold air? I am just curious as I am kind of new to automotive stuff.
  4. Chris Miller
    It takes 8 ounces of PAG 150.
    If you refill it and plug the switch back in, it should work fine on its own. Electrically, it should be fine.
    What are your high side and low side readings, and about how hot was it outside when you took the readings?
  5. 95silv001
    OK, So I pour all 8 oz in the compressor and none in the accumulator? I just want to get the oil right in the compressor and I believe that everything should work. All my actuators work properly, and the fan is fine. Does my 95 have a cabin air filter? I don't think it does. Oh and my pressure on high was about 200 I believe and low stayed at around 43-47. It was quite warm. I have one final question. Can I remove the evaporator on that truck w/o removing the whole dash? It looks like I can.
  6. Chris Miller
    Pour it all in the compressor. However, you don't need to add any if it's already full. Any oil you added to the line is in the compressor by now.
    No, there's no cabin filter.
    Your pressure sounds okay, but if it was pretty hot outside, you may still be a bit low on freon.
    In order to remove the evaporator, you have to take the whole dash out. I highly doubt you'll need to, though. If it was clogged, your pressure would be really high.
  7. 95silv001
    Thank you very much Chris. You have been very helpful, and I will go and check pressures again this evening. Also, thanks to moogvo for the advice.
  8. 95silv001
    Hey, does anyone know if new condensers come with orifice tube pre-installed? It looks like the one I picked up has one already, but I want to be sure. Thanks, Jordan.
  9. Chris Miller
    Some models have it in the condenser, others have it in the line nearby. Follow the line from the condenser and look for a crimp in the line about 3 inches below the fitting. If you've got a tube in the line, you don't need the one in the condenser.
  10. MauryFrench
    MauryFrench Rockstar 100 Posts
    Be careful with the Orifice tube in a new condenser. Mine came with the wrong size for my Chevy Truck.
    Also, here is a paper about oil totals in Compressors. http://www.rtitech.com/downloads/News/Oil Chart - Compressor.pdf . It says no more than 3 total in the Compressor. I would think the other 5 would go to the accumulator if 8 oz is correct.
