abs acting weird
Discussion in 'Lifted & Offroad Suspension' started by 98Z713dr, May 18, 2010.
  1. 98Z713dr
    98Z713dr New Member
    tried searching didnt find anything.
    scenario: priodically when coming to a stop just as im getting to almost a complete stop the abs kicks in for a few seconds and then is fine. no abs light on and it doesnt do it everytime time i stop. not sure where to start looking. i have only had the truck a week it has 172k on it. i have changed and flushed all fluids except for the brake fluid havent got a chance to yet. its pretty dark in color so i know it needs changed and flushed. could this be causing it? or is there an abs sensor starting to go bad just not bad enough to set a light? it seems like its the right front wheel but not sure. any info would be helpful thanks guys.
  2. 2COR517
    You don't say what year your truck is, but pretty common problem for older trucks with that kind of mileage. It is most likely a bad wheel sensor in the front. You could try changing or cleaning the right side and hope that fixes it.
    But it would be money well spent to take it to a shop that can watch all the wheel speed sensors at once while you drive it. In my case, the ABS controller was bad, I pulled the fuse.
  3. 98Z713dr
    98Z713dr New Member
    its a 98. yeah i know those can be expensive i was looking at a 99 while back it needed one and it close to a grand or so
  4. 2COR517
    Duh. I just read your user name LOL:lol:
  5. msvx95
    msvx95 Rockstar
    Mine did this after the front hub abs sensors were corroded...replaced both hub assemblies a few years ago and it did it again. So recently I just bought two new ones, installed and drives like new.
    My abs light never came on on either occasion but I know what you are going through. It drives you nuts and just gets worse. Change out your hubs $175/per and some labor.
  6. Land Shark
    Land Shark Rockstar 100 Posts
    I had to replace a wheel sensor in the front of my truck. Not just the sensor the whole hub and sensor. Good times. Once I did that I had no problems.
  7. msvx95
    msvx95 Rockstar
    yes you can't replace only the sensor because it's not replaceable by itself. Poor design where you have to replace the whole assembly :(
  8. murdog94
    And as a stop gap till you can get it repaired pull the ABS fuse so you know you can stop when you hit the brakes.
  9. msvx95
    msvx95 Rockstar
    Good idea...mine was so bad I almost crashed in a parking lot trying to park!
  10. Beer Belly
    Beer Belly Rockstar
    My local Chevy Dealer pulled and cleaned my ABS Sensors as a courtesy.....been fine ever since
