ABS and break light
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by vaugeois1985, May 6, 2010.
  1. vaugeois1985
    vaugeois1985 New Member
    what can i check first for the codes to go away my truck is very sensitive to when the oil is low, radiator fluid, ecxt, ecxt, now ABS and (Breake)<-------
  2. vncj96
    If your ABS and break light is on I would bet the EBCM is shot (electronic brake control module) it operates the ABS, but your normal brakes will work fine.
  3. Loggerhead Mike
    there are several things that can cause an abs light. bad brake switch, wss ect ect. never replace an ecm unless you diag it
    you need to take it to a dealer to get checked out. the codes will not go away untill the problem is fix'd
