ABS and Emergency brake light
Discussion in 'Lifted & Offroad Suspension' started by nthammack, Jun 5, 2010.
  1. nthammack
    nthammack New Member
    My 2000 Silverado throws ABS and Emergency lights on the dash more and more often. Brakes still work fine, however i know that ABS does not when the lights are on. I can reset the computer and the ABS works and the lights go off, but then when i cut the engine off and cut it back on, the lights come back up. Anyone else have the same problem?
  2. tbplus10
    At work I recently had the same problem on a 2007 Kodiac 6500, different model truck but the systems are similiar.
    We ended up having the front and rear ABS sensors replaced because they had holes worn in the leads, and the power steering pump was replaced because it wouldnt build enough pressure and was setting off the low pressure sensor in the pressure line. Neither issues caused the brakes to act different but the alarm was going off almost constantly.
