ABS pulsing
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by nbturbo, Apr 3, 2012.
  1. Pikey
    You can always pull it out and look at it. If the tip has any wear then the sensor wheel is making contact with the sensor and the hub needs replaced. I always just replace the hub. I would hate to spend $75 on the sensor, then in a few months I have to spend $200 to replace the hub because the sensor went bad again. Some info for you the resistance of the sensor should be between 855 and 1230 ohms. I don't know if that will help you with your decision, but it gives you more to test. If the resistance comes back ok then I would assume that the sensor wheel is rubbing the sensor.
  2. nbturbo
    nbturbo New Member
    Thanks, they have a few sensors and bearings in stock, so tonite I will take it apart, see how the sensor looks and check the resistance. If it looks sketchy, I will then just buy the whole bearing, if it looks ok, then just the sensor. Thanks for the intelligent advice, I really appreciate it. I also have vw's and frequent the vortex forum, which has mostly posers whose first comment on someone's car pic is to write "lower it".
