Adding a sub, where to thread a power cable
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by Kraziken, May 13, 2011.
  1. Kraziken
    Kraziken Rockstar 100 Posts
    Anyone else do some of their own wiring for car stereo? I've hooked up my own head unit and speakers, but somewhat concerned about where to punch a hole (or is there an existing spot I can use) to get a power cable to the rear of the Burb to power the amplified subwoofer.
    Suggestions?
    I have a '98 K1500
  2. 1991 Suburban
    1991 Suburban Rockstar 100 Posts
    Just find an existing grommet that you can thread it through. That's what I had to do on my '91 Sub. Not very difficult to do.
  3. Enkeiavalanche
    Enkeiavalanche Loving the Outdoors 4 Years ROTM Winner 5000 Posts
    What Ga wire are you running? What amp are you useing?
  4. Kraziken
    8 Gauge wire. It is a kicker powered sub, so I have the wiring pulled from my old rig. I don't see spot I can thread thru and suspect I'll need to drill a hole.
  5. Kraziken
    After looking at some other forums, I traced the antenna lead back into the cab thru the passenger side. It was behind the coolant overflow bottle. I'm a car stereo noob, but gaining confidence with every small job I do. :)
