    Join Today ~ It's Free
adding an amp
Discussion in 'Audio, Video & Gadget Tech' started by 2Kbowtie, May 18, 2009.
  1. 2Kbowtie
    2Kbowtie New Member
    I have a 2001 S10, with a stock cd player. The truck has only dash and door speakers as far as I can see. Is there a way I can hook up an amp without springing for a new head unit? If there were rear speakers then I would just use that signal. Since there are none....
  2. 97chevz71
    97chevz71 New Member ROTM Winner
    yes there is a way. you just need a converter.
  3. 2Kbowtie
    2Kbowtie New Member
    Could you possibly go a little more in depth requarding this?
  4. 97chevz71
    All i know is that when i was getting and amp and wiring done. the guy was doing it said he could hook the stock radio up fo that you can run rca plug so you could run a amp. It is some kind of adapter. But he said the stock radio would limit the bass so i went witha unit. But since you are only runing door speakers it should not be a problem.
  5. vncj96
    vncj96 New Member 1000 Posts
    First do you have an extended cab, or one of the four door ones, either way you have rear speakers, if its four door the are in the rear doors at foot level. If you have an extended cab they shoud be about half way up the rear cab on the side of the truck. What the other guy is referring to is a line out converter. You splice into existing wiring to speakers and run the wires back to the converter. The converter has line in connectors on one side and RCA outs on the other, then you run the rca to the amp. then you just run your ground, power and remote wire like normal and your set.
  6. 2Kbowtie
    2Kbowtie New Member
    It is nly an extended cab and there are no rear speakers. I have searched for them and they are not there. There are no grills for them either. I used the stock radio and moved the fade to the rear of the truck and it only plays in the doors. The front fade plays it on the dash only. Does anyone know where I can find one of the convertors since I am stationed in germany and they are not so technical on this stuff here.
  7. vncj96
    WWW.CRUTCHFIELD.COM Is this a european truck or something that you had shipped over to Germany?
  8. 2Kbowtie
    2Kbowtie New Member
    No its not. It is from Talahassee Florida. I know that Crutchfield says there are rears but there isnt. If I need to post a pic of my interior to prove this then I will. But there are no rear speakers and it is a US truck.
  9. vncj96
    So very weird, I have never heard of them not having rear speakers:neutral:. I had a sonoma and mine had 4x10 in the pillers behind the extended cab window. Of course this was not a model that had a third door.
