Adding just 1 more inch
Discussion in 'Lifted & Offroad Suspension' started by LisaO925, May 5, 2009.
  1. LisaO925
    LisaO925 Rockstar
    Can you add an inch to an already existing 3" lift? Or, do you have to get a whole new lift kit?
  2. werty
    werty Rockstar 100 Posts
    what kind of lift...do you know???:neutral:
  3. silveradotrailblazer
    What year and type of truck and what lift kit installed?
  4. LisaO925
    LisaO925 Rockstar
    89 Chevy Suburban 4wd 1500 Skyjacker
  5. adampaul1964
    If it is a solid front axle, which I think it is, you should be able to add leaves to the spring packs or even have them re-arched, years ago I did the same thing to Dodge pick up I had. It had a 4" Rancho lift kit and I had a local spring shop re-arch the front springs. remove the rear lift block (4" block) add 2 leaves and re-arch the rear springs to give me a total of 6" when all said and done.
  6. silveradotrailblazer
    I agree with Adampaul1964. Re-arc or add a leaf.
  7. Pete95Sierra
    yup you can add a leaf the front and put a block in the back
