Adjusting power steering pulley
Discussion in 'Member Introductions' started by Mysuburban99, Jan 19, 2012.
  1. Mysuburban99
    Mysuburban99 New Member
    Hi everone I have a problem with my 99 suburban. I have read a lot of threads about belt noise and the best thing I have heard is to adjust power steering pulley need to know how to do that any help would be great
    Mike sterling heights michigan
  2. retired2001
    Welcome to the G M T C ! If you don't get an answer here, post in one of our "technical" forums. Good luck!
  3. SurrealOne
    Welcome! You should likely post in one the technical forums as more people will read your inquiry than here.
  4. Coach24
    Welcome to the Club. Check tension before adjusting anything. Also check the belt for shiny surface which may indicate one or more pulleys may be frozen. Also check belt for cracks. If belts look good Get a bar of Ivory soap, start your engine and carefully hold bar of Ivory on inside of belt for about 30 seconds. It usually takes away all those Halloween sounds(Screeching).
  5. Mysuburban99
    Thanks for the help I will give that a try
  6. Coach24
    let us know how it goes
