After market tach?
Discussion in 'General Chevy & GM Tech Questions' started by Knucklehead, May 12, 2009.
  1. Knucklehead
    Knucklehead Rockstar 100 Posts
    Is there a way to install an after market tachometer to a vehical that doesnt come with a stock one? I like to keep an eye on my rpms but my burban dont have a tach!
  2. 2COR517
    You can pick one up at Autozone or wherever. Should have instruction to connect to your HEI.
  3. 89burban
    89burban New Member
    I have an 89 burban went bought an autometer tach all you gotta do is set the switch on the tach or in the tach to 8 cyl then run your 12 volt main power to the tach then you run your dimmer to it or just a 12volt for the light and the last wire goes to your coil there should be 4 wires on it 1 with a clip that goes to nothing and i belive it is white just hook the tach up there and blame its done really easy to do
  4. crane557
    crane557 Rockstar 100 Posts
    Nice! I want to hook one of these up.
