Aftermarket intake and maf
Discussion in 'Performance & Fuel' started by Trask215, Sep 6, 2008.
  1. Trask215
    Trask215 Rockstar 100 Posts
    Does anybody know if putting a new aftermarket intake setup on my '01 chevy would somehow mess with the mass air flow sensor? I've seen aftermarket sensors in catalogs like summit and stuff so it got me wondering. Thanks.
  2. Calbaby968
    Calbaby968 Rockstar 100 Posts
    It will not mess up your MAF. The MAF recognizes the amount of air coming in and adjusts automatically to it. A nice cold air kit will start making it breathe better. I've talked to some pros about a bigger MAF, like the 80mm over the stock 65mm. Bringing in more air can hurt the performance side of things. I am getting my truck dyno'd this week and will find out if it does hurt it. I switched to the 80mm MAF a couple weeks ago.
  3. 04sierracrewcab
    so an intake plus a 80mm maf is good??
    what kind of power/mpgs?
  4. Trask215
    ok, thanks. I want to get dual exhaust before anything else though. Right now The exhaust leaves that cat and converges into one and that's it. We cut the muffler out but dual exhaust, one out each side behind the tires, will look reall good.
  5. Calbaby968
    the intake will help it breathe and produce a few ponies. I put a 80mm maf on but I have to have it dyno'd to see if it hurt or helped the hp. I was saying I talked to a couple pros about it and they said it could be hurting the performance side of things. It's bringing it more air than what the intake can handle eccentially. I also put on an 80mm throttle boy. When I go to the dyno, I"m going to do a few runs with what i have on now, and then swap out parts to see if I'm going up or down in numbers. The idea is to help it breathe to make it run better. But you have to realize that more HP means more fuel has to be burned to achieve that hp. The other thing you can do is go with a forced cold air induction. They sell kits at parts stores, or you can fabricate one with aluminum flex from lowes or home depot. Just run it under you bumper and up to the filter/cone. When the air comes in and goes right to the filter it's "forced" cold air induction. You may still get under hood heated air, but with the forced air, it's all fresh cold air. I'll post when I get the dyno done.
  6. hutch_pt
    hutch_pt Rockstar 100 Posts
    I have a K&N FIPK and a Jet MAF. They work well together, but it does occasionally throw a check engine code, stating that the truck is running on a lean mixture. I had to take the MAF out and clean it real good (autozone sells aerosol MAF cleaner/do not touch the filaments!) which took care of the problem temporarily. I called JET and they told me that the oil from your filter builds up on the filament, causing the lean mixture reads, the sensor is thrown off with the oil on the filament.
    I do have a Hypertech programmer as well, which may be part of the issue.
  7. Calbaby968
    I have cold air, maf, and throttle body, plus the hppIII and have never received a code. My MAF is a Granatelli. How long after you clean out the MAF, does it kick out the code? Or is this just after you clean your air filter and re-oil it?
  8. 04sierracrewcab
    oh ok i get it now ... yeah let me know what your results are..
    what happens when it rains (concerning the forced air)
  9. Calbaby968
    air is lighter than water. It won't pick it up to the filter. Think about in all the ram air style hoods. It just collects there and then evaps. Doesn't make it to the motor. Maybe a little moisture or condesation.
  10. 04sierracrewcab
    how does it connect to the filter??
