Aftermarket Rims/Tires and PSI Sensors?
Discussion in 'Wheels & Tires' started by CornhuskerChevy, Aug 16, 2009.
  1. CornhuskerChevy
    CornhuskerChevy Rockstar
    How hard is it to put the sensors on new rims and tire off of the stock ones? I have an 07 silverado, and just thought of that.
  2. Jimmiee
    They are very easy to change. Keep in mind the PCM knows the location of each sensor so if you change that location you have to tell the PCM that you did so. On late vehicles this can be done without a scanner but no so with older vehicles. Check your owners manual as it will tell you how to reprogram them.
    Here's a picture of a sensor:
  3. CornhuskerChevy
    Thanks Jim!
  4. Z71_guy
    when you go to install them make sure to get a rebuild seal kit for them or they will leak
