Aftetrmarket XM replacement antenna problem
Discussion in 'Audio, Video & Gadget Tech' started by Lance915, Nov 1, 2008.
  1. Lance915
    Lance915 New Member
    I need to disconnect the original factory roof mounted XM antenna from my 2005 Silverado and replace it with an aftermarket antenna. The problem I am running into is connector compatability when I attempt to plug the new antenna into the XM unit mounted behind the glovebox.
    I purchased a TERK micro size antenna and the end connector would not fit into the XM the plastic end connector was totally different.
    Anyone know what the next option is???
    A local stereo shop said cutting and splicing the antenna was not a very good option, and didn't know of any aftermarket adapter..
    ANYONE know...
  2. tlperry68
    You may want to place the new micro attena on the dash board near the twilight sensor. Check with your shop. Or run the new wires out by the third brake light.
  3. Lance915
    Lance915 New Member
    Thanks but location is not the problem...
    The problem is that I can not find an after market XM antenna that will snap into the XM receiver unit located in the glovebox.
  4. RAPTOR_660
    RAPTOR_660 Rockstar
    Which XM unit do you have?I have the Skyfi 2 & I've seen 2 different types of connectors on the antennas.I believe the Terk has a pink plastic piece on the end,correct?If so,can you just pop it off?
