Air conditioning out in Yukon XL
Discussion in 'General Chevy & GM Tech Questions' started by stubble, Aug 16, 2010.
  1. stubble
    stubble New Member
    Hi, yesterday the AC stopped blowing cold. Fan works, compressor seems to kick on and the engine changes idle as a result, but only ambient air comes through. What to I check?
    63k miles, 2003 Yukon XL 2500 4x4.
  2. MightyMax
    MightyMax Rockstar 100 Posts
    Will it blow cold if you are moving and only warm when sitting still??
    I would get guages and check pressure....quick and easy first check.
    Maybe also go through your fueses and make sure you have not blown a fuse.
  3. Loggerhead Mike
    first is to check pressures
    more than likely got a leak and lost the refrigerant.
    with ac running check your ac lines. cold side should be cold, hot side hot. check for frosted places wich would indicate a restriction
  4. stubble
    stubble New Member
    Thanks for your replies guys
    This morning I found the A/C belt on the ground. It had broken. DOH! Well there's your problem! Pullies seem ok, so I'm just going to replace it.
    Appreciate the replies.
  5. MightyMax
    Yep, I would agree I would check the belt first. :D
    Good Luck with him.
