Air in brake lines will not go away.
Discussion in 'Lifted & Offroad Suspension' started by stevenje98, Jul 1, 2010.
  1. stevenje98
    stevenje98 New Member
    2001 Suburban 2500 All Disc brakes.
    I have air in my brake lines only on the left front and left rear.
    I installed new brake pads all the way around the truck. I bled the brakes when I was done with a vacuum bleeder. I noticed this problem is with left front and left rear brake lines having air in them. So I figured I would try a different bleeder. This time I used a bleeder that goes on the brake reservoir ; still the same problem. No matter what bleeder I use or what sequence I bleed the brakes, there is still air in the brake lines on the left front and left rear only. The front left get allot of air, more than the left rear. The other side, right front and right rear are fine with no air in the brakes lines.
    Last year I had this problem before. This was after a shop installed a new master cylinder. My brakes seemed mushy after this. The manager said this is normal. Well I did bleed them myself a week after this install and had this same problem.
    I never seen so much air bubbles come from a brake line .It just don’t stop no matter how much I bleed the brakes. So I’m wondering if this shop installed a bad master cylinder or there is bad seal in the master cylinder or they forgot to bleed the master cylinder.
    Any input on this situation would surly help. My truck does brake better, but still kind of mushy.
  2. TrailLeadr
    TrailLeadr Epic Member 5+ Years 1000 Posts
    You either have a bad seal, one of your fittings is loose or cross threaded, or you have a bad line somewhere else that air is entering from.
    I would check the fittings around the master. see if they're loose or cross threaded first.
  3. kgibson181
    kgibson181 Epic Member 5+ Years 1000 Posts
    Yeah if you've tried all of those bleeding techniques then its definately a bad seal or fitting somewhere. Tried just doing a simple gravity bleed yet?
