Airbag service warning light
Discussion in 'GM Electrical Tech' started by NCDaywalker, Dec 29, 2010.
  1. NCDaywalker
    NCDaywalker New Member
    I recently closed the door on my glovebox a little too vigorously. After that, the service airbag warning light came on. Is there an easy fix for this annoying message from the message center in dash and turn off the red warning light in the left upper instrument cluster?
  2. dpeter
    I do not have an answer for you but I do have some questions. Are you sure the glove box and light are related or just coincidental? Do air bags have diagnostic codes that can be used to help?If closing the glovebox a little too vigorously caused the problem, then perhaps a loose connection is to blame. Don't know about air bags but be cautious. Good luck
  3. TexasEdition
    TexasEdition Rockstar 3 Years 500 Posts
  4. NCDaywalker
    airbag question
    2005 Silverado LT 4.8
  5. NCDaywalker
    I have had a tight schedule at work last few weeks and have not has opportunity to try Texas's suggestion at this point.
