Amp help
Discussion in 'Audio, Video & Gadget Tech' started by sfilipe, Oct 10, 2009.
  1. sfilipe
    sfilipe Member
    I need someone to recommend an amp to me. I need either a 2 x 300 rms at 4ohm or two monos at 300 rms at 4 ohms. The only thing is that it has to be 10.5" x 7" x 2". It could be longer then 7" but would have to have less height. Going at an angle.
    That is all the room I have. If it is two monos I can mount the other one somewhere else but I need at least one to fit in this space.
    Any help would be great. Thanks.
  2. Chevyman224
    Chevyman224 Rockstar 100 Posts
    why can't you have a mono amp that pushed 600watts rms?
  3. MTPockets
    MTPockets Rockstar
    Why don't you run a 2 ohm load instead of 4 ohm load.
  4. sfilipe
    sfilipe Member
    Anything your guys recommend would be great. Pretty sure I messed up what I want anyways. lol I have two dual voice coil 2+2 ohm subs. I need an amp or two doesnt matter b ut at least one of them has to be within the dimension above. Thanks!
  5. Chevyman224
