AMSOIL's P.i. Performance Improver Concentrate (API) (Money back Guarantee
Discussion in '1st Synthetics' started by 1st Synthetics, Feb 26, 2009.
  1. 1st Synthetics
    P.I. Guarantee
    Improves fuel mileage an average of 2.3% and up to 5.7%. Reduces emissions such as hydrocarbons (HC) up to 15%, carbon monoxide (CO) up to 26% and nitrous oxides (NOx) up to 17%. Restores power and performance. Reduces the need for costly higher octane fuel. Reduces noise from carbon rap and pre-ignition. Offers better vehicle drivability and smoother operation.
    Reformulated for greater potency
    See Pricing Information or Place an Order
    Package sizes include:
    12-oz. Bottle
    12-oz. Bottles (case of 12)
    Untreated Fuel Leads to Poor Engine Performance
    A vehicle demonstrates its best efficiency and engine performance when it is new. As the engine ages, its performance suffers from gasoline fuel-generated deposits that form on the fuel injectors, intake valves and combustion chamber. Additives are required to control deposit formation.​
    Today’s fuels, however, lack sufficient treatments of either enough additives or high quality additives. Fuel system deposits result in the following:​
    • Lost fuel economy
    • Lost power and poor throttle response
    • Failed emission tests
    • Poor drivability - surging, hesitation, stalling, rough idle
    • Engine knocking (pinging) and rap
    • Difficult starts​
    Treated Fuel Delivers Maximum Performance
    AMSOIL P.i. is the most potent gasoline additive available today. As a concentrated detergent, it is unsurpassed in cleaning combustion chamber deposits, intake valve deposits and port fuel injector deposits. AMSOIL P.i. helps maintain peak engine efficiency, fuel economy, power and drivability in newer low mileage engines. In engines with accumulated deposits, testing showed AMSOIL P.i. provided the following clean-up benefits after only one tank of gasoline:​
    • Improves fuel mileage an average of 2.3% and up to 5.7%
    • Reduced emissions
    • hydrocarbons (HC) up to 15%
    • carbon monoxide (CO) up to 26%
    • nitrous oxides (NOx) up to 17%
    • Restored power and performance
    • Reduced need for costly higher octane fuel
    • Reduced noise from carbon rap and pre-ignition
    • Better drivability
    • Smoother operation​
    AMSOIL P.i. works as an “emissions passer.” It is ideal for use prior to emissions inspections. ​
    Unsurpassed Deposit Clean-up
    Port Fuel Injector Deposits form after the engine has been shut down and there is no gasoline flowing through the injectors. During this “hot soak” period the injectors heat up and the gasoline remaining in the injectors degrades and forms deposits. This can happen very quickly with the use of poor quality gasoline and short trip driving. Because the clearances within the injectors are extremely tight and injectors must deliver precise amounts of “atomized” fuel, even small amounts of deposits can cause injectors to malfunction. Fuel flow is reduced and spray patterns are disrupted, decreasing engine efficiency, power and fuel economy, while increasing exhaust emissions.​
    Intake Valve Deposits form on the intake side or back side of the valves. As deposits increase, they restrict airflow and alter airflow patterns in the cylinder. The deposits disrupt the balanced air/fuel ratio by momentarily absorbing and releasing fuel, and they can cause valve sticking by getting in the way of the valve stem and guide. Deposits also restrict proper seating, and the valves may be burned. Intake valve deposits cause lost engine power, increased emissions, poor engine efficiency and potential valve failure.​
    Combustion Chamber Deposits form on the top of the pistons and on the cylinder heads. They increase compression and absorb heat during combustion to later release it during the intake cycle. In some engines with tight squish domes, combustion chamber deposits cause the piston to actually hit the cylinder head. This is referred to as combustion chamber deposit interference or “carbon rap.” Combustion chamber deposits also flake off as they get large, and these flakes can get trapped between the valves and valve seat, resulting in compression loss, difficult starting and rough idle.​
    Higher compression and stored heat cause increased intake fresh charge temperatures and the increased likelihood of pre-ignition “knock” or “pinging” when the fuel spontaneously combusts prior to spark ignition. This increases emissions and may cause engine damage. Many of today’s cars have “knock” sensors that adjust spark timing to prevent knock.​
    Although audible knock is controlled, power is lost from retarded timing. Higher octane fuels of 4-5 octane numbers can be used to help prevent knock, an effect called “octane requirement increase.” As a vehicle ages, more expensive higher octane fuel is needed to keep it operating at peak performance. By cleaning combustion chamber deposits, knock is controlled, power is restored, fuel economy increases and higher octane fuels are less necessary for peak performance.​
    Maximum Fuel Economy
    AMSOIL P.i. maximizes fuel efficiency by dissolving and removing fuel system deposits and other contaminants for improved power and overall performance.​
    Thank you,
    Scott Douglass
