Another Request For Cam Information
Discussion in 'Performance & Fuel' started by Goldie, Nov 2, 2013.
  1. Goldie
    Goldie Epic Member 5+ Years 1000 Posts
    I am considering adding a cam to my 4.3L engine. A company by the name of Camquest (www.camquest.com) offers one that is advertised for "economy, torque, and mild performance gain". I'd like feedback from members experience with the company and results if you have used one of their cams. Any other recommendations are welcome.
  2. dobey
    COMP Cams makes one heck of a lot of cam shafts. As far as quality of machining goes, you shouldn't have any problems if you go with a COMP cam.
    You mostly just need to figure out what grind you want for your engine, and pick the numbers that match what you want, or come up with some numbers and see if they will do a custom grind with your numbers. Picking good numbers is very hard though, as a lot of external factors will affect how well the cam performs, including headers, exhaust, intake, ignition, etc…
    A mild cam with a grind designed to help boost low end torque though, in a stock engine, sounds like it would be fine. More low end torque is really what you want in a truck, as it will help with launching and getting up to speed, and help improve fuel economy a bit, depending on how much torque you gain, and how the torque curve is affected by the cam.
  3. Goldie
    Thanks for the reply. Since I've never messed with cams it sound like I've got a lot work to do. At their site they have a form you fill out to give them a lot of information. However they are very slow responding.
