anti lock brake probs
Discussion in 'Lifted & Offroad Suspension' started by bigproskine, Nov 27, 2009.
  1. bigproskine
    bigproskine Member
    when ever you hit the bakes to stop get below 5 mph and anti lock brakes kick in.. what is my problem? when you hit the break hard fells like it pulls the tire o5 silverado 4x4 ext v8 4 wheel disc brakes. got any advice for me??
  2. bigredb714
    bigredb714 New Member
    I got a 2003 chevy silverado reg cab 4.8 v8 4x4 and i got the same problem with my brakes. I dont know what the problem is but i really need to find out before I end up in a accident. Let me know if you figure out what the problem is and I will do the same. Thanks
  3. getawaycars
    getawaycars New Member
    It's probably a bad sensor at one of the wheels.
    You'll need to have the abs system computer scanned at a repair shop to figure out which one.
    BASSIST Rockstar 100 Posts
    You have a wheel speed sensor that is dropping out at low speed and needs replaced
  5. hore_racing
    hore_racing New Member
    i got an 03 yukon with the all wheel drive system and it does it too at low speeds as well as when starting off from a stop the traction control will freak out and pull power some times im pretty sure its a wheel speed sensor as wheel since they are used for both abs and traction control im gona look into it some more this weekend and let ya know
    - derrick
  6. Beer Belly
    Beer Belly Rockstar
    I thought I read somewhere that there was a recall for late 90's- early 2000 trucks for" unintended low speed ABS activation" dealer sez that my year (2006) was not covered, called GM and asked if they were going to expand the recall, they said "no".....I wrote the NHSTB to report the problem to try and get a recall GM, write the NHSTB and maybe this will be extended to later years.
  7. hore_racing
    so i just did a hub assem on my LF and the abs seems to be happy again... and no more traction control freakin out so ya i think that fixed it ill put a few more miles on it this week and see if it fixed it for sure
  8. bigproskine
    bigproskine Member
    yes the abs wheel speed sensor i gues the are pron to rust and go bad
    thats the problem
  9. BillNH
    BillNH New Member
    Its a wheel speed sensor. I ended up changing both hubs and sending GM the bill and they paid it. I got the recall after I changed them.
