anyone have a rusty frame?
Discussion in 'General Chevy & GM Tech Questions' started by chevyman2004, Jul 21, 2009.
  1. chevyman2004
    chevyman2004 Rockstar 100 Posts
    My 04 silverado has a very rusty frame. there isn't a speck of rust on the body but the frame has lots of it. I don't know what i should do or how to prevent it. please help
  2. Falcone
    Falcone Rockstar 100 Posts
    you can get it rustproofed where they spray the underisde of your truck with oil which coats it, not too expensive and some people swear by it,
  3. chevyman2004
    how about the rust that is already there? it's all over so just grind it all off or is there another way?
  4. tattooed4life
    tattooed4life Epic Member 5+ Years 500 Posts
    I used black tractor implement paint from tractor supply. I just went over everything with a scotch brite pad and painted away. Been about a year and still looks good.
  5. cartier
    cartier New Member
    the best way i say would be to get an drill and buy the wire brush (circular item with a bit at the end so it fits in the drills chuck) then remove the rust that way (wear goggles as well) then after your done that get an oil based lubricant ( or home remedy mix grease with transmission fluid and spray it on to the frame and stuff) in my experience i find the black stuff that looks like rockguard just peels of and makes the rust worse casue it holds moisture.
  6. spottweld
    spottweld New Member
    do you park in a moist area or do you live in a state that puts salt on the roads during the winter. and as to protecting it you have a couple of choices take a wire weel to the rusty spots and pirmer then paint. you can also use undercoating. or you can pull it all apart and have the frame sand blasted then primed and painted
  7. 2COR517
    Unless you get every spec of rust out, paint is just covering up the problem. POR15 is supposed to be a great product, but it's a lot of work to do correctly.
    You could use a product called Fluid Film. You can get it at a John Deere dealer or others. About $35 for a gallon. You can put it right over the existing rust. Any current moisture will get out, and the FF will keep it from rusting further.
  8. 2ToNe04
    its going to be hard to remove all that rust out unless you take off your cab and bed and get rid of all the rust.
  9. kylegillean
    kylegillean Former Member
    yeah ive got the same problem. im just spraying rustoleum undercoating on it after i wire wheel it. no sense of going all extreme for some surface rust
  10. bry2500
    Clean off the rust with a wire brush or even stuff called "NAVAL JELLY". Don't get it on paint it will take it right off. Then paint it with POR-15. It will be indestructable after that.
