astrostart remote starter
Discussion in 'Chevy Truck Accessories' started by Z71_guy, Dec 27, 2009.
  1. Z71_guy
    I bought the truck with the starter installed with no remote, got a new remote and it works great only problem is some times it wont start right away.
    it starts and stops instantly and does not try to go again its not showing and fault codes everything else works perfect
  2. simon243
    simon243 New Member
    I have the same problem
  3. Pikey
    Does it run for about 3 seconds and then die? If so, it is an issue with the security bypass
  4. simon243
    simon243 New Member
    It will fire run for a bit a 1 second then stop,
  5. Pikey
    That definitely sounds like you have an issue with the security bypass module that is installed
  6. simon243
    simon243 New Member
    It is all so flashing a code it is 12 flash of the light
  7. Pikey
    Wait a minute. What year is the vehicle? You are indicating it is pre 1996 with obd1. A 12 code nears everything is ok
  8. simon243
    simon243 New Member
    It is a 2003
  9. Pikey
    When is it flashing 12 times? How do you get it to flash?
  10. simon243
    simon243 New Member
    The light on the controller next to the 9 toggle switch flash when key is off
