Audi LED Daytime running lights
Discussion in 'Lighting Discussion' started by roadking666, Nov 1, 2009.
  1. roadking666
    roadking666 New Member
    Has anyone installed a set of LED's like the ones on the new Audi's. I have a 2006 silverado. I bought a set from and looking for a way to connect them. I was told I had to use a 12v limit switch because the truck runs at 13.5v and will burn the led's out. can anyone help? Thanks.
  2. unplugged
  3. Crawdaddy
    Moved to Electrical
  4. pmf608
    im building my own led drl's. im putting 9 led lights on each side into the little filler panels under the headlights on my 2001 silverado. having them under there should help protect them from rocks. once they are both ready to go, i will wire them to the drl circuit and change my existing drl spot in the light housing to work with park/turn, like the one beside it. i will also wire the led drls to come on with the parklights so they will be on at night also (should be a cool effect)
    - just throwing my design out there -
  5. aboston
    aboston Member
    How is your LED setup coming along?
  6. pmf608
    i have both sides built, but i have only sealed the back of one side. i have tested both sides and they work, and are brighter than i expected. Once i get the wiring sealed on the second one, i will put them in and wire them to come on with the DRL's and with the parking lights. i will also post pictures.
