audio question?
Discussion in 'Audio, Video & Gadget Tech' started by Foxracer, Aug 23, 2011.
  1. Foxracer
    Foxracer Member
    im looking at a 6 disc factory from a 04 colorado for my 06 silvy. its rds which i know need programed but will the radio swap work??? im getting this one in mint condition for 50 bucks shipped
  2. sstoner911
    The harness should be the same,however, is the dash the same as far as mounting it size wise?
  3. Foxracer
    Foxracer Member
    idk i think so if not ill make it work.. thanks
  4. nmc2010
    nmc2010 New Member
    to be honest with you man your better off goin with an aftermaket. do you have the bose system in it?
  5. ntbush83
    I say go for it! Not sure about the harness though. Wouldn't be hard to match up wires though.
  6. Foxracer
    Foxracer Member
    i dont want aftermarket, being in national guard still i want factory plus u like how the factory looks
    they are same harness... finally got a hold my buddy that works from a chevy dealer and he said it should work it being rds just needs programed to the vin
    radio cost 62 dollars shipped and program will be 40 dollars
    alot cheaper then aftermarket
  7. sstoner911
    Post some pics when you get it installed!
  8. Foxracer
    Foxracer Member
    will do it has same mounting holes as my 06 silvy does
  9. dobey
    Just to clarify… the need to reprogram the radio for the right VIN has nothing to do with it having RDS or not. RDS is a signal broadcast from radio stations, which lets you see song/traffic/whatever info, being broadcast from that station. A lot only broadcast the station ID. However, on most all newer GM vehicles, the radio is integrated into the VATS/PassKey setup.
  10. Foxracer
    Foxracer Member
    vATS/passkey plz explain
