Auto ride problems on 05 Yukon XL 1500
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by joscibo, Jun 6, 2013.
  1. joscibo
    joscibo New Member
    Autoride compressor no longer functions and the shocks need replacing. Looking for advise on a economical fix. Used compressor and new shocks? Aftermarket shocks that have a way of fooling the computer that it is functioning? Used compressor on car-part are available but I'm not sure if it would pay if it will be short lived? Is the compressor able to be rebuilt?
  2. Pikey
    You could always buy a set of standard bilstein shocks and install them. You will then have an annoying service ride control light or message. You can buy a pack of resistors at radio shack (around $4) and install them on the sensor wires to get rid of the light. I will try to find the post that says what resistors to use.
    - - - Updated - - -
    it looks like 10W 2.2ohm resistors will work. Check out this thread, post #2 http://www.gmtruckclub.com/forum/showthread.php/123655-Autoride personally I would go with bilstein rather than monroe.
  3. joscibo
    joscibo New Member
    I thought I would bring this back up. I just had a quote on replacing the compressor and shocks! Ouch! $1800 to get it back on track. Does a guy but a compressor off of car-part and shocks as well? Used shocks concern me a bit and I'm sure the compressor failed because of a constant run if the shocks were leaking. Is there a way to test the shocks or do I buy a used compressor and see if my shocks will still function? If the shocks are bad I can buy new or used at that time?
  4. Pikey
    personally, I would just do away with the system all together as I stated above. You are looking at around $360 for 4 new bilstein shocks and 2 new bilstein rear coil springs. The new rear air ride shocks alone will cost you that.
    I have not seen compressor rebuild kits. you could probably run air from a garage compressor to check the shocks. But, if it is a slow leak you may never find it. I would not waste the money. Arnott makes replacement air shocks for it, but they are $350 for the kit. not worth it in my opinion. I would not buy used, you may just be wasting money on someone elses problem.
  5. joscibo
    joscibo New Member
    346.JPG 070.JPG 072.JPG 075.JPG I decided to sell the 05 Yukon XL and bought a rust free2000 Suburban LT from North Carolina. It has coil over shocks o avoid his problem down he road. It has 169,000 miles and has had the tranny rebuilt in the last 4 months and both leather front seats have been redone. I had a good friend go look at it and when he meets up with us on our hunting trip he is going to deliver it to us here in Wisconsin. I will be on this forum more often as this will be the family rig for a while. The wheels on he white one I sold with it but I will be getting another set similar probably this winter. The bLack one is the new one.
