Video Back up cam not on in reverse
Discussion in 'Audio, Video & Gadget Tech' started by davidlmc, Nov 25, 2011.
  1. davidlmc
    davidlmc New Member
    Hello, I just installed a Kenwood DNX6160 with a backup camera in my 2007 NBS Silverado.Everything seems to be fine except when i put the truck in reverse the camera does not come on, but if you push the cam button on the front then it comes on. Any help would be great.
  2. sstoner911
    Your camera needs to be wired in to the reverse circuit......on Your BCM (located under the dash panel below the steering wheel)is a dark blue wire(tan plug) - could be pin 7 or pin 11. You can test with a test light to see which wire is for reverse.
    Should look similar to this: ignore the red test clip!
  3. SurrealOne
    Dang, I could have told you which wire on the BCM if it was a 2007 (Classic), but I don't know for NNBS.
