Bad Gauges - Fixed!
Discussion in 'Audio, Video & Gadget Tech' started by mhevezi, Mar 9, 2009.
  1. mhevezi
    mhevezi Rockstar
    Sometimes I amaze even myself!
    So my '04 Silverado had the wacky gauges that would only work about 10% of the time. Only the tach and water temp gauges worked reliably and the speedo- not at all. So I called the dealer for the recal and because of my mileage, no dice. A re-built cluster is like $230+ and having it fixed by someone who swaps out all the bad stepper motors is $150, plus shipping and a few days with no gauge cluster.
    Being somewhat frugal (ie- I'm a cheap a$$), and having some skills, I decided to tackle the gauges myself. I found a set of all 7 stepper motors (the extra for the clusters with the optional tranny temp gauge) for $46 shipped to my door. Took about 4 days to arrive, and I went to work.
    Getting the instrument panel out is a piece of cake. It snaps apart fairly easy, and if you have ever soldered components to a PCB, then you will have no trouble with this. Aside from a few blunders on my part, it went smooth and I am proud to say that all my gauges are ALL working 100% for a fraction of what I would have had to pay!
    If anyone has messed up gauges, and you can handle a soldering iron, you can get the new motors on e-bay for cheap and in less than two hours, have your gauges back!
    1 person likes this.
  2. Springthing
    Thanks for the wonderful information. Please tell us what vehicle and year you have and fixed. I believe this fix is only available for around '02 and up or so.
    Thanks again,
  3. retired2001
    Good info', thanks for sharing!
  4. tlperry68
    Good info to know. Thanks.
  5. dwill3015
    Great advice!
  6. mhevezi
    mhevezi Rockstar
    It's for the '03 to '06 Silverado's and the '07 Silverado Classic. Those gauges had a recall, but you need to be less than 70k miles to qualify for the recall. I'm not sure if the '02's and older had the same issue.
    It's a pretty easy fix if you have basic mechanical skills, can solder and just take your time.
  7. bry2500
    Way to go on the frugal fix.
    I hope I never have to follow your example.:lol:
  8. Springthing
    Same issues, no recall on them. We had another thread on here of someone that had sent away to get the stepper motors swapped but when I contacted the person that was doing the work I was told it was not possible for my ('99) year. I think pre-'02 is the cut-off.
    Again, great info!
  9. stprovost
    stprovost New Member
    Hello, where did you order the stepper motors? I also have a 2003 chevy suburb with the spastic gauges!
  10. mhevezi
    mhevezi Rockstar
