Battery issues
Discussion in 'General Chevy & GM Tech Questions' started by mjclsi, Jun 26, 2009.
  1. mjclsi
    mjclsi New Member
    My 1997 Chevy Suburban is having power issues. It won't start without a jump. Then, it stays running fine, but if it is powered back off of any length of time, it won't start again and has to be jumped. I have tested the alternator...fine. I have pulled disconnected the positive battery cable, and when you run it across the post...sparks fly. I've pulled each fuse one-by-one, and the sparks still happen. What am I not thinking of? Somewhere, something is drawing current, but what? Any tips would be greatly appreciated!
  2. zubbiez
    zubbiez Epic Member 5+ Years 500 Posts
    time for a new battery
    if its the original it sevred its purpose, batteries wear out take it to a autoparts store they can test it for you if it just needs a charge theyll charge it for free, or let you know its time for a new one.
  3. mjclsi
    mjclsi New Member
    The battery is about 4 months old, and has worked like a charm. This issue started last week. Happened once on Wednesday, then again on Monday, then again last night. The truck sat from Monday evening until Thursday evening. Did it again today.
  4. zubbiez
    Id get it tested sometimes you get a bad one. it may just beholding a enough of a charge to start it in a few hour period but them loses the charge if left for over a day,thats what happened to mine when it started to go. take it to where you got it at the best you get a new battery at the worst you take the battery of the list off things it could be.
  5. vncj96
    Here is a NO COST test for you!!!! Get the truck running, then run it around a bit to get the battery charged back up. When you get home DO NOT shut the truck off. Disconnect the battery from the truck, if it dies you have an alternater issue. If thats the case DO NOT run it like that, alternaters can lock up and this could break your belt and cause other damage!!
