big brake kits
Discussion in 'Lifted & Offroad Suspension' started by flatsstalker1, Jun 30, 2009.
  1. flatsstalker1
    flatsstalker1 Member
    any suggestions on a big break kit for a 07nbs sierra??
  2. TRPLXL2
    For big brakes are you talking about upgrading to like 6 piston calipers, with a 15" rotor from BAER or WILWOOD or BREMBO? What kind of horsepower are you running right now, if you are just stock then you don't need a $5,000 set of brakes. If you are going with dual STS turbos or a supercharger then yes I would go with the "quick change" WILWOOD setup, It is similar to having a quick change rear end.
  3. grimreapersshadow
    grimreapersshadow Rockstar 100 Posts
    exactly dont toss the money in the hole if you dont need it only reason i have larger brakes is becuase ive got alot of of engine work in mine and didnt really need it till i broke the high 300 horses line and i drive mine on the street alot
  4. vncj96
    Dont waste the money, get some steel braided brake lines and just upgrade the pads and rotors on stock clipers.
  5. MYMIXEDUPMIND
    MYMIXEDUPMIND New Member
    Contact SSBC Stainless Steel brakes Corp. in New York, they have many options for stopping a truck better I just ordered a 14" rotor upgrade kit that uses the stock calipers so you don't even have to bleed the brakes...my 2004 Denali is fast, but doesn't stop worth a sh*t!
