Biggest Tire on 2001 GMC Sierra SLE
Discussion in 'Wheels & Tires' started by Atlas77, Sep 21, 2011.
  1. Atlas77
    Atlas77 New Member
    What is the biggest tire I can put on my stock 2001 GMC Sierra SLE Ex Cab. I found an awesome deal for a 15' rim with 32/11.5/15 tires. Will they fit?
  2. o3gerber
    o3gerber Rockstar 100 Posts
    Depending on the backspacing of the rim they will fit, you might have to tighten up the torrion bars a bit to prevent the tire from rubbing. Is yout truck 4 wheel drive?
  3. Atlas77
    Atlas77 New Member
    2 Wheel Drive. Should i just invest in a leveling kit that raises the front and the rear? 4 rims with brand new tires, for 400. They look amazing
  4. dsfloyd
    If I remember right 15's wont fit because they will hit on the caliper. I had a 2000 z71 and thats what I was told. 16 was minimum. I know my current truck with 16's if they dont put the stick on weights in the right spot they will hit on the caliper as well.
  5. Atlas77
    Atlas77 New Member
    Dang i totally forgot about that, i believe i read that on here awhile back ago . Well i think im just going to get bigger tires on the factory chrome 16's they look good anyways. Thanks everyone
  6. Rockstarrchevy81
    Rockstarrchevy81 Rockstar 3 Years ROTM Winner 1000 Posts
    Yeah man you will need a 2.25 inch leveling kit to fit around a 33 or raise your torsion bars either one will work with a 32 11.50 for sure will no rubbing.
  7. chevyman2004
    chevyman2004 Rockstar 100 Posts
    Yeah they say u can only go up in size from stock rims u can never go down in rim size
